i hear a whining a noise coming from my car i have learned it is NOT my power steering pump what else could it be?
whining noise
Re: whining noise
if it goes away ~15minutes after start up...AIR system. If it gets louder when you push on the accelerator...alternator whine. If it's coming from the rear end of the car when driving...it could be your 10 bolt taking a crap on you.
Re: whining noise
my car has a whining noise also, i seem to hear it when i am engine braking in 1st or 2nd gear the most.
it has done it since the day i bought it (50,000 miles ago) and im not really worried about it because i have heard a lot of 3.8's that make the same noise
Re: whining noise
Originally posted by Bonemaro View PostDoes it go away after the car warms up?
No the car was warmed up already
Originally posted by xsvtank View Postheater core?
I just replaced that five thousand miles ago
Originally posted by atomicvirus View Posti had the same problem a few days ago after i changed my tranny fluid. i didnt put enough in and it made a whining noise. it went away when i filled it.
ok cool thanx ill check my fluids
Originally posted by DRTYBRD View Postif it goes away ~15minutes after start up...AIR system. If it gets louder when you push on the accelerator...alternator whine. If it's coming from the rear end of the car when driving...it could be your 10 bolt taking a crap on you.
Ding ding alternator whine . Whats the fix ?
Re: whining noise
you have an AC? sometimes it's the bearing in the AC pulley. When in doubt, use a stethoscope or a large screw driver to you ear when the engine is running and put it on each individual part of the engine VERY CAREFULLY!!!! to find out where the sound is coming fromLast edited by tcrenegade50; 11-20-2009, 03:56 PM.
Re: whining noise
Originally posted by tcrenegade50 View Postyou have an AC? sometimes it's the bearing in the AC pulley. When in doubt, use a stethoscope or a large screw driver to you ear when the engine is running and put it on each individual part of the engine VERY CAREFULLY!!!! to find out where the sound is coming from
Yeah I have a/c in my car . Does that really work ?!?!?!
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 days ago
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 weeks ago
