My car has been 1 step forward and 2 steps back. The more I fix it the more it fails. My Evaporator Core had a leak so I replaced it. Now that everything is patched up there is a big leak coming from the compressor clutch. Is there any way to fix this or am I just screwed and have to buy a new compressor? The pressure on both the low and high side are fine (35/140) yet I can see the UV dye coming out the clutch face and flinging it all over the engine bay :(.
R134a leaking from Comp-clutch. Anything I can do?
Re: R134a leaking from Comp-clutch. Anything I can do?
you can fix it, but IIRC its almost just as costly to replace the whole compressor as it is the clutch.
edit* you may be able to buy a seal kit and install it.. but it probably wont help if it is wore down
i got my compressor off ebay right before last summer for cheap like a a hundred sumthin heres a new one for $150.(i bought my accumulator from this guy) i wouldn't advice gettin a used one though i first got it to save like $30 put it in and it was no good the same guy has a rebuilt one for $119.
http://cgi.ebay.com/ebaymotors/NEW-A...s#ht_500wt_751
If your the oringinal owner and had it replaced under warranty you should have a lifetime GM Good wrench lifetime warranty on it, mines been replaced like 4-5 times in 14 years for free parts/labor. Along with 5 altenators, 3 water pumps,2 starters, its nice when they have to do $300 jobs for free. If left stock they also will do injectors, shocks, and a few more items.But I would just swap in the reman. one and use the fill up cans that have stop leak and 2oz. of oil in each can. If it is warm enough where you live you might not have to evac. the system. I know when I did mine it was like 105 out with 15% humidity so it worked great. Usedd the refill setup at Napa.Last edited by ssms5411; 11-28-2009, 07:42 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by whiteMaro View PostOk thanks guys. I don't want to buy something like this used. Looks like I can get a refurb one for around $180. I'm just going to wait till after the holidays to replace it.
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...1 day ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...1 day ago
I stopped driving...3 days ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...1 week ago
by KubesI notice a lot of headlight assemblies on amazon for 1998-2002 but zero for 1997. Am I to assume it’s not possible to upgrade from my 4 rusted out light...1 week ago
