low rpm's - FirebirdV6.com/CamaroV6.com Message Board
low rpm's
  • low rpm's
    my rpm's are dropping at cruising speed, they drop to 1500. what can cause this??
    Re: low rpm's
    umm sounds normal.... going into overdrive to save ur gas.
      Re: low rpm's
      really i tough i was tripping out, it doest it when in between 2 and third. i havent gottent in on the highway after the shift kit install
        Re: low rpm's
        yeah i dont think its anything to worry about. i dont have a shift kit so i cant help there. it also depends on what gears ur running as to what rpms u run. but i cruise under 1.5 rpms a lot and i have 3.42 gears.... in fact i like to try to keep it at 1.5k cuz i like the way it sounds between 1.5-1.8k lol
          Re: low rpm's
          lol ima try to catch some vid so i can show you, i have 3.23's so idk if its normal with those gears
            Re: low rpm's
            Sounds normal.
              Re: low rpm's
              the lower the gear number the less rpms it should run... so that sounds right
                Re: low rpm's
                With my 3.73 gears and Transgo it shifts down to around 1500-2000 so I would say its normal.
                  Re: low rpm's
                  the only that i might find weird is that when the rpms are down and i give it some gas it downshifts to go move.
                    Re: low rpm's
                    sounds normal to me... it doesnt have a lot of power down in there in a high gear, so it downshifts when u want more speed
