turn signal question - FirebirdV6.com/CamaroV6.com Message Board
  • turn signal question
    what is the piece called that the combo lever goes into?
    is that the turn signal switch that looks like the cancel cam?
    Re: turn signal question
    The cruise control/wiper lever goes into the turn signal switch. It's relation to the turn signal is that it is the lever, but the switch is internal to the steering column.
    The cancel cam houses the horn wire and does not look like the turn signal switch except for possibly a match in color. You must remove the cancel cam to access the turn signal switch.
    Last edited by fenderman; 12-05-2009, 10:03 PM. Reason: Added some additional info on cancel cam
      multifunction switch or turn signal switch are the common names
      http://www.bowtiev6.com/
        thanks guys, so this is the part i need then?:
          Yep, that's the turn signal switch and what the turn signal lever fits into.
          Also, make sure the steering wheel is positioned in the straight ahead position so that the airbag coil can be reinstalled properly. If you have a shop manual it should detail the necessary steps for all of this. If you need any more help, don't hesitate to ask.
            thanks, i have access to ondemand5, and hopefully it will give me instructions, if not i have the haynes, and you guys
            i will probably get the part tomorrow and do this on monday
            now, a question, would anyone happen to know if a balancer remover will fit on the steering wheel?
              A harmonic balancer puller should work as long as you have the correct bolts to thread into the steering wheel itself. Most of these types of pullers I've used come with an assortment of bolts for a variety of tasks. I know the one I have in my toolbox is labeled as a steering wheel/harmonic balancer puller.
                cool, i dont remember what i have, but im sure i can rig something up if needed
                thanks
                  hey guys, i just took my whole dash apart, that that is the wrong part, the piece i need is what the lever plugs into, not that piece
                    just for future reference, i need a "pivot and pulse switch" NOT the turnsignal switch
                      Could have sworn it was all one piece. Oh well, I stand corrected. Thanks for clearing that up and sorry to have misinformed you.
                        nope, and the thing that sucks is no parts stores have it, i think it is a dealer only part
                        edit* it is also called the windshield wiper switch
                        • Andy H
                          Transmission removal help!!
                          by Andy H
                        • 2.8 Bird
                          Abs inop
                          by 2.8 Bird
                        • fishin
                          by fishin
