when i hit a hard acceleration and my rpms get way up there i bog like a mofo. its quick and it fixes itself real quick. what could be causing this? its consistant when i hit close to redline. only started happening after the power pack install. any help is appreciated. its real consistant, i can go outside right now and make it bog if i punched it wot.
i'm bogging!!!!
What converter you have now?97 Red Firebird<br />Best N/A 1/4: 13.98<br />Best N/A MPH: 96.13<br />Best Nitrous 1/4: 12.49<br />Best Nitrous MPH: 108.53<p>2001 Pewter Camaro SS <br />GTP Stage II Heads, Pig Cam, Holley Intake, SLP Headers, SLP Lid, Vigalante 3600 Stall Converter, MagnaFlow Cat Back Exhaust, Duel Electric Cut-Outs<br />11.26@121
2800 stall
i was told that maybe my converter is kicking in too early. redbird, is that what you are thinking? i was also told maybe too much gas, or not enough gas.
6s.......under the hood or under the belt, they just dont cut it.
Maybe its knock retard? Have you ever tried autotap or a scanner of some kind? give us some readings so we can help betterJustin<br /><a href=\"http://www.bass482.com/firebird/index.html\" target=\"_blank\"> 2000 Black Firebird A4 Y87<br /></a>170.2rwhp/203rwtq (SAE Corrected)
i never used to hit the rev limiter before, would it just start happening? i know my times at the track would be more of what i expected if i could get away from this. this is of coarse after i installed the power pack and cai.6s.......under the hood or under the belt, they just dont cut it.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...6 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
