Part Recommendations?? Prices?? Approximate costs for installation??
Fuel Pump Replacement
Re: Fuel Pump Replacement
Originally posted by Jaysan View PostYeah but was going to do that trap door thing but I was worried I would smell gasoline . But isn't the fuel pump in different places for different years ?
the only way you'll smell gas is if you have a leak ... which would need to be fixed anyway
if you search the forum you can find picture of both locations of the fuel pumps ...
Trap door FTW, no gas smell my dremel made some sparks and nothing and I made a deadmat door for it and taped it on. Really easy, make sure you cut more by the disconnect lines makes it easier.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostTrap door FTW, no gas smell my dremel made some sparks and nothing and I made a deadmat door for it and taped it on. Really easy, make sure you cut more by the disconnect lines makes it easier.sigpic
Originally posted by 2000camaroRS View PostDoes the Walbro 255 come with all components necessary for the replacement?sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Originally posted by Shodown View PostThere are no other components. Remove the old pump, install new pump, done.1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
