I have a massive power steering leak i cant figure out if its leaking from the reservoir the hoses or the pump itsself. I went to autozone to check the price on them, they only stock the pump without reservoir, so i guess ill have to go to a dealer. Does anyone know of a similar problem or a way to test the hoses or reservoir or the pump for that matter, thank you very much
96 RS dark green, 1st drag race ever 8/6/04 r/t .126, 1/4..16.142, mph..83.65, home made 3\" exhaust(ill post pics soon)turbo muffler, home made CAI<br /><a href=\"http://www.cardomain.com/memberpage/666045\" target=\"_blank\">http://www.cardomain.com/memberpage/666045</a>Tags: None
oh i also wanted to ask does anyone know of a high performance steering pump, is there any reason to get one. what would it do for me96 RS dark green, 1st drag race ever 8/6/04 r/t .126, 1/4..16.142, mph..83.65, home made 3\" exhaust(ill post pics soon)turbo muffler, home made CAI<br /><a href=\"http://www.cardomain.com/memberpage/666045\" target=\"_blank\">http://www.cardomain.com/memberpage/666045</a>
hey which honeywell do you work at96 RS dark green, 1st drag race ever 8/6/04 r/t .126, 1/4..16.142, mph..83.65, home made 3\" exhaust(ill post pics soon)turbo muffler, home made CAI<br /><a href=\"http://www.cardomain.com/memberpage/666045\" target=\"_blank\">http://www.cardomain.com/memberpage/666045</a>
man I had a massive leak once, a hole bottle in like 5 mins. of driving and it ended up being a metal tube on the rack and pinion that was rubbing something and put a pin size hole in it and the pressure in the tube shot the fluid out and all over the place.<a href=\"http://www.cardomain.com/memberpage/594989\" target=\"_blank\">http://www.cardomain.com/memberpage/594989</a>
I had a leak in my high pressure hose... a lot of volume thru a very small hole...couldn't see the hole until I had the car on a lift with the engine runningJoel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
last night i repaired it, just like you sayed once i got under it i wiped every thing down and found the leak, there was i pin hole leak in the high pressure hose, i rented a puller but didnt use it. i just removed the plastic cover from the steering shaft and squeezed in there, the bottom was 18mm, the top was 16mm. make sure you lube and put the o-rings on the new one. it feels like i have air in there or the steering is less responsive, does anyone know why. maybe i screweed the pump or something else up. thx96 RS dark green, 1st drag race ever 8/6/04 r/t .126, 1/4..16.142, mph..83.65, home made 3\" exhaust(ill post pics soon)turbo muffler, home made CAI<br /><a href=\"http://www.cardomain.com/memberpage/666045\" target=\"_blank\">http://www.cardomain.com/memberpage/666045</a>
I had my whole PS pump crack a couple of days ago, it leaked like crazy, there was so much smoke from the burn off it looked like my car was on fire. I went to the mechanic, it cost $200 to repair which wasnt that bad but im smelling the fumes and its still smoking 3 days later from the 2 bottles of PS fluid I put in it that pretty much went right thru it.Check my 01 vert firebird at <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=376416\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=376416</a>
You can check and make sure the o-rings seated properly. If there was air in the system, it would eventually work its way out I would think if everything was put back correctly. ( By the way, I work at Honeywell Engines & Systems next to the airport, in the Gear manufacturing center as a maintenance mechanic.)95 convertible 3.8 series II
hey saved 1, I work for a machine shop that builds a lot of your parts, were s.e. of the university curve on 36th and superior, i deliver parts to you guys almost every day in my delivery camaro.96 RS dark green, 1st drag race ever 8/6/04 r/t .126, 1/4..16.142, mph..83.65, home made 3\" exhaust(ill post pics soon)turbo muffler, home made CAI<br /><a href=\"http://www.cardomain.com/memberpage/666045\" target=\"_blank\">http://www.cardomain.com/memberpage/666045</a>
Originally posted by azrscamaro:
last night i repaired it, just like you sayed once i got under it i wiped every thing down and found the leak, there was i pin hole leak in the high pressure hose, i rented a puller but didnt use it. i just removed the plastic cover from the steering shaft and squeezed in there, the bottom was 18mm, the top was 16mm. make sure you lube and put the o-rings on the new one. it feels like i have air in there or the steering is less responsive, does anyone know why. maybe i screweed the pump or something else up. thxJoel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
Originally posted by CARdiac:
</font><blockquote>quote:</font><hr />Originally posted by azrscamaro:
last night i repaired it, just like you sayed once i got under it i wiped every thing down and found the leak, there was i pin hole leak in the high pressure hose, i rented a puller but didnt use it. i just removed the plastic cover from the steering shaft and squeezed in there, the bottom was 18mm, the top was 16mm. make sure you lube and put the o-rings on the new one. it feels like i have air in there or the steering is less responsive, does anyone know why. maybe i screweed the pump or something else up. thx1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
