Why do so many people have a totally wrong-headed idea about injectors and when and if you need to change their size?
Maybe it is the old school 'bigger carb' school of thought, but how many times have I seen someone thinking that bigger is better - revealing a total ignorance of just how engine control systems and injection work.
And I wonder how many idiots out there went blindly ahead and installed larger injectors (which of course will adjust to supply exactly as much fuel as the old smaller injectors would have), perhaps causing themselves problems with idle if the injectors chosen are large enough as to be unable to supply lean enough mix at minimum cycle?
FI has been around a long time - why are so many owners back in the last millennium with their thinking? Bigger isn't necessarily better, guys. :rolleyes:
