help fast - FirebirdV6.com/CamaroV6.com Message Board
help fast
  • help fast
    i removed my crankshaft pully to see if the seal was leaking, (it wasn't) so i put the pully back on and now my car cranks but it won't turn over.
    i'm going to get it sit for an hour to see it the engine flooded. what else could it be?
    WAWA-A-HOLIC
    Cranking is turning over. You mean it won't start?
    Did you remove the crankshaft position sensor? If so, did you reconnect it and install it correctly?
    If you have a scan tool, does it show an RPM while you're cranking?
    My guess is something with the CKP.
    Matt
    1998 Mystic Teal Camaro M5
      i did remove a sensor, and i did reconnect it.
      WAWA-A-HOLIC
        Chatting with you on AIM now.
        Matt
          ok guys this is where i am now, i still can get her to turn on. so i ordered a crankshaft pos. sensor, hopefully this works.
          when i was down there i did spray some break cleaner to get oil off from down there. maybe it shorted it out.
          WAWA-A-HOLIC
            ok i changed my crankshaft pos. sensor, and my camshaft pos sensor and now she is fine. thanks for all your help
            WAWA-A-HOLIC
