Biggest injector for the 3.4 - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Biggest injector for the 3.4
    Originally posted by SpeedingFirebird View Post
    I already have 19# installed. Been running them for a few years. You think they are enough for 8 PSI?
    already installed. :tup:
    I think you should be alright but I would check the air fuel ratio out with a wide band to be on the safe side.
    • #17
      I think you and I already had this conversation when I was talking about 6 psi. :burn:
      I am working on installing the wideband now. Do you know if Accel sells an extender cable?
      http://www.cardomain.com/memberpage/799659
      • #18
        I ran 24lb injectors with the Vortech fmu with 15 lbs of boost but I had to modify my stock fuel pressure regulator to 18lbs of pressure at idle.
        Cold starts were rich but once the o2's kicked in every thing was good.
        I also used water/meth injection for extra fuel and to keep the motor safe.
        • #19
          I'm surprised you ran it with 18psi. 24# inj, I was at 5psi and used a 8-1 Vortech FMU.
          • #20
            18lbs was as low as I could get it. There was a restriction hole under the fuel pressure regulator on the fuel rail that prevented too much fuel to return to the gas tank. I did open the hole a little. How were you able to get the fuel pressure down to 5lbs?
            • #21
              Gutted the stock regulator and used a cheap in-line on the return.
