the needle will drop to 0 then instantly go back up once at a complete stop and only when i press the brakes. Oil level is fine. please help i am scared to drive my car.
oil pressure gauge dops to 0 when im braking
Re: oil pressure gauge dops to 0 when im braking
It sounds to me like an electrical issue or a problem with the sensor. Have you checked the alternator voltage when this happens? Our cars (3.8's - I don't know about 3.4's) sometimes have a power dip when you hit the brakes. Mine does it once in a while. However, it does not make the oil pressure gauge drop. Rather, the lights dim for a second then come back up, especially if there is a lot of load on the electrical system.
The way you will know for sure what's up with the oil system is to hook up a mechanical gauge and watch it while you drive. If it works normally then it's probably a bad sensor. That would be the first easy and cheap thing to fix. Next would be to try and locate an intermittent short in the circuit leading to the gauge.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...3 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...4 weeks ago
