got ???? - FirebirdV6.com/CamaroV6.com Message Board
got ????
  • got ????
    looking at a camaro/firebird fpr on ebay do you guys think its a good buy and i plan putting my 1997 camaro back on the juice
    :burn:
    Re: got ????
    got a link of the one in question? Why do you need a fuel pressure regulator? What's wrong with your stock one?
    http://www.bowtiev6.com/
      Re: got ????
      got something wrong in the fuel system so i am going to replace every thing fuel related till i find the problem
        Re: got ????
        the fuel pump and filter have been replaced
          Re: got ????
          what kind of issue? Just replacing everything seems like a waste of money to me
            Re: got ????
            it will start and run for about 3to 4 sec thin die. showing 5 psi at the fuel rail change fuel pump and filter no change and it ran fine thin it just die and did not start back up than i started buying parts and putting them on
              Re: got ????
              What's the fuel psi when you turn the key on and cycle the key? Does it get around 45 then?
              Security light on?
                Re: got ????
                no when you try to start it gets 5 psi. if you turn the key on and off a couple times it gets up to 10 psi then it will run for 3 sec or so
                  Re: got ????
                  security light go off before i start it
                    Re: got ????
                    do you have a link of the ebay FPR you are looking into?
                      Re: got ????
                      do not know how to do the link but if you go to ebay its under camaro/firebird fuel pressure regulator
                        Re: got ????
                        I am not seeing the direct replacements for our cars on ebay.
                          Re: got ????
                          than maybe the ones i am looking at will not fit but it did say universal 0-120 psi but did not say v6 or v8 and they are blue and red just in case you may have miss it
                            Re: got ????
                            copy the address from the ebay piece and paste it in your reply...
                              Re: got ????
                              just go to autozone and buy one, they should have it on hand. Those you are describing are universal ones and not direct replacements.
