fuel pump - FirebirdV6.com/CamaroV6.com Message Board
fuel pump
  • fuel pump
    is this the fuel pump that most people upgrade to? Even though it says 5.7 on the listing?
    http://www.summitracing.com/parts/GRN-GM722-2/
    Re: fuel pump
    Looks the same , but there are some on ebay that are $100 shipped , I went with the high flow version 255, I have one in the car since 2002, and also have a spare one I bought in like 03' becuase I thought mine was bad but the line was just off the pump. The high flows will have better high end top flow where the reg. ones will start to fall off. They have a chart that shows them side by side. But I think the 96-97 pumps are different than the newer style you have. Good luck with it, if you can ditch the bucket and use hose clamps to put everything together mine came out pretty good. You could also PM 97RS4Life since he sells them too, see if he can hook you up with the right pump.Thanks again for your help yesterday.
      Re: fuel pump
      yea that's the one to go with. I am out of them right now and have to special order them from granatelli. So it takes 1-2 weeks for mine to get drop shipped. Looks like summit has them in stock right now
      http://www.bowtiev6.com/
        Re: fuel pump
        thanks, and i also have a 100 gift card to summit sooo... :D
          Re: fuel pump
          its actually not the right pump, it does not have the ventri port and you need to cut the bucket to make it work, so i guess ill be sending it back
            Re: fuel pump
            I ditched the bucket with mine, maybe the new ones you can't do that too?
              Re: fuel pump
              i didnt want to ditch the bucket, wanted to keep the ventri port and the new pump does not have provisions for that.
              sooooo...
              alternatives?
                Re: fuel pump
                Once I get my nitrous installed the walboro 255 fuel pump and injectors will be next.
                  Re: fuel pump
                  sooooo...
                  alternatives?
                  Cutting the bucket open at the top and modifing it and using a safe glue for gasoline to put it back together. Theirs a writeup somewhere on the net. I know I used hose clamps to put everything back together for mine works perfect. Like 97RS4LIFE I don't know about the newer ones, but would like to have the plastic gas tank for weight loss. LOL
                    Re: fuel pump
                    fwiw i fund this pump
                    http://www.fullthrottlespeed.com/ite...S1DFFP+eq++Tp+
                    maintains the stock fuel system/bucket
                    • 187shark
                      by 187shark
