I tried to change the plugs for the first time today in my 01 Firebird. But I couldn't get the boot off of the plugs. I pulled and pulled and pulled. Does the factory put some lock-tite or something on them? How do I get them off? Also, I got the 8 mm Taylor wires from Thunderracing.com. But they gave me 90 degree boots on the wires. Is this right? Currently, it looks like the facotry wires are 180 degree and they have some sort of metal shield over them. If I use the 90 degree, will I have to cut the metal shield?
Please help ...Plug and Wire Install
Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>Tags: None
You just gotta have the touch! j/k That's how my taylor's are, they'll be fine. You don't ahve to use any heat shields with em', just make sure they are not pressing against an exhaust manifold.Whisper Lid/K&N Intake, NOS 5175 Kit w/ Polished Bottle, Moser 3.42\'s w/ Auburn LSD, SLP Ram Air H.O. Hood, Pacesetter Ceramic Coat Headers-3\" in/out hi-flo cat, 3\" I-pipe, Edelbrock Muffler, Boyd Coddington Smoothie Two\'s
Domestic Violence ... just to clarify. Thunderracing.com sent the 90 degree bends. i.e. both ends are 90 degrees.
Thanks guysZaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...4 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...6 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
