3.8 camaro removal - FirebirdV6.com/CamaroV6.com Message Board
3.8 camaro removal
  • 3.8 camaro removal
    Whats the easiest and fastest way to remove the engine from a 96 3.8 camaro, when removing from the top.
    Re: 3.8 camaro removal
    easiest and fastest is to do it from the bottom. So change that part of your statement and your set. Otherwise you have to remove a bunch more stuff to get the engine out.
    http://www.bowtiev6.com/
      X2 , search advance tech , there are some pictures of lifting the body and rolling out the engine and trans together. Than it goes back the same way.
        Its doable from the top but way more difficult. It has been argued over and over though so do it the way you want.
          i took the motor out of the top, ill never do it again. Take the 8 (idr how many) bolts out and drop it out of the bottom, it will save so much time and anger haha Goodluck!
            like these guys said, its a real PITA. i have done it. if there is absoluely no other option, we will help u as much as possible
              lets put it this way, you will need an engine lift to take it out from the top, well, you will also use the engine lift to lift the front of the car to get the engine out.. so basically you use the same exact equipment to do the job
                DO NOT TAKE IT OUT THE TOP!! lol thats how i did it, biggest pain in the @ss. Remove bolts holding the k-member to the chassis then Use an engine lift to lift the front of the car up leaving the motor and wheels on the ground. Just watch clearances and go slow so you dont snap any ac or brake lines.
                Just a v6 with a few mods, no big plans :bs:
                  Deff bottom! You might be supised how easy it is
