i have a feeling i have a leaking injector and i have to replace the o rings...my question is how is the best way to replace the o ring and how do i do it? i hear taking the intake manifold makes it easier to take off the fuel rail and injectors but how do you remove the intake manifold and how do you remove the fuel rail and injectors? thanks
intake manifold/injectors
Re: intake manifold/injectors
pull the map sensor off yout intake manifold (left side) its a b!tch then take all the injector wires loose take the 4 bolts out that hold the injectors down pop the fuel rail up and slide it back then over the intake manifold it is not easier to remove the manifold.. actually i don't know if you can remove the manifold without taking the fuel rail out first because its blocking some bolts..2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
