Bad lifter? - FirebirdV6.com/CamaroV6.com Message Board
Bad lifter?
  • Bad lifter?
    So my buddy has a 98 trans am auto well tonight we were out crusing and chasin down ricers and **** when starting ticking, checked oil just to see and it was fine. So we headed back to my house and as we're driving sometimes it ticks and sometimes not if we hit a bump it seems to stop and it dose not tick at idle but if it is a lifter shouldn't it tick all the time? Any in puts would be great. Thanks guys.
    3M MAFIA
    ________
    | Dynomax Catback | Auburn Posi | 3:42s | B&M Ripper | DIY CAI | PVC Mod |
    Next on the list: GT2 Cam| 105# Springs |Headwork| Headers |
    Re: Bad lifter?
    in to jack your thread or nothign i have the same problem i get a tick after i drive the car around for a while but i dont know if its and exhaust leak or what. my mechanic said i heard a leak since we used crappy bolt to hook the manifolds to the y exhaust pipe. i bought the the replacement bolts at the stealership four bolts for 25 dollars but havent got around to put them yet to if its the problem
      Re: Bad lifter?
      It's cool man.
      3M MAFIA
      ________
        Re: Bad lifter?
        every morning when i go out and fird up my car it ticks for about 5 minutes then goes away. pretty much does that every time its started if it has sat for more than a couple hours. should i also be concerned? my mechanic says its ok, just the oil is at the bottom of the engine and it needs time to circulate. thoughts? also not trying to jack your thread man.
        perhaps this is a job for seafoam?
          Re: Bad lifter?
          does the tick change with change in RPM?
          http://www.bowtiev6.com/
            Re: Bad lifter?
            i THINK lifter ticking goes away as the engine warms up.
            1998 Chevy Camaro 3.8
            1997 Chevy Camaro Z28 - SOLD 7-23-2011
            1996 Chevy Camaro Z28
            2001 Pontiac Firebird Formula
              Re: Bad lifter?
              How many miles on motor? I would try seafoam that stuff is amazing!
              Just a v6 with a few mods, no big plans :bs:
                Re: Bad lifter?
                Ya well kinda, it dose sometimes.
                No cause we sat in the walmart parking lot for like 2 hours letting the engine cool down, and as it warmed up the worst it got. Thats why we are not so sure if it actually a lifter or not.
                3M MAFIA
                ________
                  Re: Bad lifter?
                  I thinks its around 150k not positive, I've heard bad and good stuff about seafoam.
                  3M MAFIA
                  ________
                    Re: Bad lifter?
                    weird i haven't heard anything bad if done properly. did it to my car and it runs as strong as ever.
                      Re: Bad lifter?
                      Hmm well I'll look for a write up on it and see if my buddy wants to try that.
                      3M MAFIA
                      ________
                        Re: Bad lifter?
                        http://www.ls1tech.com/forums/genera...-your-car.html
                        its the writeup for an ls1 but its the same exact thing on a v6 if you have any questions pm me....if it doesnt work your out like 9 dollars maybe but it wont damage the car.
                          Re: Bad lifter?
                          Here's the one on tech.
                            Re: Bad lifter?
                            so the lifter tick goes away after the engines warms up so in my cases it should be the i do have and exhaust leak. is ticking a a common noise? i should have the tick in the manifold area were they connect to the exhaust pipe
