Looking at MSD - FirebirdV6.com/CamaroV6.com Message Board
Looking at MSD
  • Looking at MSD
    I'm thinking of adding a MSD igition set to my 2000 3.8L.
    How many people have this on their cars? I know nothing about igition stuff...how are is it to do?
    i've read other postings about having screwed up wires, so it makes me a little nervous.
    can anybody shed some light on the subject?
    Re: Looking at MSD
    are you talking about getting msd coils?
      Re: Looking at MSD
      yeah stop looking....stock stuff works fine. havent had any luck with my msd stuff
        Re: Looking at MSD
        run stock coils, and then msd wires and pick up some plugs and your ignition is all set
        http://www.bowtiev6.com/
          Re: Looking at MSD
          Agreed. 100%. Stock coils, a good set of wires, NGK Plugs, and you will be all set.
          As for "screwing up the wires" as mentioned in the original post, just replace one at a time and you will be just fine.
            Re: Looking at MSD
            Just replace wires one at a time. Even stock wires from autozone would be fine. I would go with stock coils too. Then NGK or AC delco plugs
              Re: Looking at MSD
              i use mds coils and wires and ngk plugs never had any trouble in the 3 years i have used them. I also use the wires on my twin turbo 3000gt
              2001 Camaro 3.8 A4
              1991 3000GT VR4
              2001 Mitsubishi Eclipse GS
                Re: Looking at MSD
                Many better 'bang for the buck' mods out there.
                  Re: Looking at MSD
                  I had my MSD 8.5mm wires for almost 9 years(still look good) use boot protectors and always run NGK spark plugs. I always found my wires cheap , people selling wrong styles so I would pick up a set for brand new for $40 and NGK plugs are $2 each so you can't beat that. I upgraded to ZZP wires 10.3mm and they are alittle expensive but look outstanding and work very well.
                    Re: Looking at MSD
                    thanks for all the great info guys.
                    i just thought a MSD set-up would be nice, but it doesn't sound like it's that beneficial. i've got new plugs and wires, and of course still running the stock coils. i guess i'll leave them as-is.
                    thanks.
                    • Andy H
                      Transmission removal help!!
                      by Andy H
                    • 2.8 Bird
                      Abs inop
                      by 2.8 Bird
                    • fishin
                      by fishin
