bangs for the bucket - FirebirdV6.com/CamaroV6.com Message Board
  • bangs for the bucket
    post the things you think are the most bangs for the bucket on v6 camaros... intake, exhausts, removing things, and just everything that counts!
    Why does people say \"but it´s JUST a v6\" ???<br /><br /> <a href=\"http://members.cardomain.com/crzygeekz\" target=\"_blank\">http://members.cardomain.com/crzygeekz</a>
    torque convertor, exhaust, intake. gears and posi if needed
    2000 FIREBIRD NBM<br />Thanks to:<br />TSP, ZZP, TCI, Comp Cam, Whisper, GM, Lakewood, TrafficJamz Car Audio,HP Tuner, Alterstart, texas drivetrain and performance, BMR<br /><br />1990 BLUE CAMARO RS<br />1980 z28 <br /><br />venom-vi vice president
      Coil Packs, Plugs, wires.
      Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
        bang for the buck and removing stuff... haha
        remove drivebelt, pull the exhasut in intake. ;)
        But serioulsy in the 3.4L the biggest bang for the buck mods was opening up my exhaust. Really helped out on the top end, where the 3.4L is hurting a little.
        First setup I ran an open y-pipe, through a half clogged cat. That setup really helped me out with times. After that setup I took the cat off and ran a cheap muffler off my y-pipe, very small exhaust system.
        Those right there affected my times the most ad really opened up my 3.4L up top which used to just fall on its face around 4,000 and higher rpms.
        I cannot really say how much my lt1 driveshaft helped my times since I did a rear axle swap and got 3.42s and lsd at the same time. but either way it is lighter then a stock 2 piece one, usually only costs like $25, AND most important, is likely not to have a center bearing go bad, and cause problems(like mine did)
        As for the mods I enjoyed the most in everyday driving but only helped a little bit in racing... Sway bars, and lsd both made driving the car everyday alot more fun.
          cam
          2000 3.8 A4 Pewter Camaro
            Nitrous by far biggest bang for the buck!
              I second that, gotta love the stuff.
              Others open up your exhaust and intake. Nice easy stuff to get ya going in the right direction
              http://www.bowtiev6.com/
                Long run = FI
                  nitrous
                  1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
                    Those with a cam... it was definitely worth it?
