im tryting to shut off the air bag light since my camaro is salvage. i removed the cluster and found no bulb to remove. i took the back part of but i dint want to remove the green bords with all the solder points. im tryign to turn it off because its annoying having it on all the time i also tried to remove the fuses but it still stays on. any one know how i can turn it off. i read in thread i foudn some guy to disconnect some ground but i dont where its located???
air bag light
Re: air bag light
theres no bulb to twist out like some of them have. i dont want to tear into eaither since im not that techi to put it back together lol. i tried pulliing the fuses out and nothing. i also tough about removing the module that located under the center counsil but idk if that will make the light turn of???
Re: air bag light
You could try resetting the system... with key off and out of ignition
1. remove airbag fuse
2. disconnect driver's side and passenger side airbag by disconnecting the two plugs
a. driver's side is a 2 prong yellow connector at the base of the steering column
b. passenger side is found behind/under the glovebox and is the same kind of
connector
3. reconnect both, and reinstall fuse
4. start the car and see if the light turned off...Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
Re: air bag light
I tried but there's no removable bulb, I removed the back cover and there only a solder point there
Originally posted by nascar24jd View PostNevermind, checked your profile and saw it is a 1997.
The bulb is removable. You have to remove the cluster, then in the back of the cluster you need to remove the black plastic cover, then just twist out the appropriate bulb.
That's it...
Re: air bag light
i tried this to no succes, i also removes the the center counsil and removed the air bag module located under there and nothing and finally i removed the fuse to see if it just goes away by itself.
Originally posted by T-Mill View PostYou could try resetting the system... with key off and out of ignition
connector
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...38 minutes ago
