Too good of a deal? - FirebirdV6.com/CamaroV6.com Message Board
Too good of a deal?
  • Too good of a deal?
    This website came up when I searched for lsd on the forum. http://www.tacreationsusa.com/rear_differentials.htm
    It sounds too good to be true for a whole rear end. Is it missing anything? And if I was to buy it, would it be a perfect pull out put in installation?
    [ November 28, 2004, 01:15 AM: Message edited by: joecool ]
    The one you want is the 10-bolt 7.5" with disc brakes, 11.7" rotor w/aluminum caliper 3.42 $450 or pay $50 more and get the 12" rear rotor, same specs otherwise.
    Kinda expensive. I paid $250 (pick-up) for my '96 3.42 rear.
      seach ebay i got my 3.23 rear shiped fto my dor for 325
      www.turbov6camaro.com
      1997 3800 Series II Camaro
        I have a stock 96 auto and on this tech info on this site, it says i have 3.08. I also have drums in the back. If I buy a 3.23 with disk brakes would the speedometer be off?
        [ November 28, 2004, 01:20 PM: Message edited by: joecool ]
          yea it will be off some unless you get it recalibrated
          http://www.bowtiev6.com/
            What tools or accessories would I need if I just bought a used complete rear end? It comes with disk brakes so I would figure that I can just hook up the old lines my drums were using. Also, how long of a job would switching out the rearend be?
              I bought a rear off of a 96 T/A for 300 bucks. Swapping it out wasn't a big deal. You'll need a ratchet set, a torque wrench for taking off your wheels, a C-Clamp for when you bleed your brakes.. I can't think of anything else. It's a pretty simple little 2 hour job.
              Tom<br />Too many mods for this sig.<br /><a href=\"http://www.l337server.com/Tom/cars.html\" target=\"_blank\">My car\'s site</a><br /><br /><a href=\"http://www.FullThrottleV6.com\" target=\"_blank\">www.FullThrottleV6.com</a>
                I'm thinking about getting the 96-97 3.23 10-bolt 7.5" with disc brakes, 11.7" rotor w/aluminum caliper for $350. I have drums in the rear so when I replace the rear end, I would just hook the abs and brake lines up right?
                Also, would I need new parking cables or bushings for the new rear-end?
                  I have a 96 that this sounds perfect for, would I need to get the ASR? or would the one without do fine?
                  96 Firebird, Ram Air Hood and Airbox, Magnaflow Catback & hi-flow cat, Dynomax Bullet muffler
                    I would go without it because my 96 doesnt have asr. Im still wondering about how im goin to fix the speedometer and if the regular brake lines for drums will work on the disks from the new rear end
                      Non-traction control rears connect the same between V6 and V8 - there is one brake line that goes to the T-fitting which services both sides.
                      It took me longer than 2 hours, even with air tools and an extra set of hands. All the suspension bolts were rusted nice and tight, even soaked em all with liquid wrench. Broke an end link swapping the bar so had to get a new set.
                      You need the ebrake cables from the disc rear. They disconnect from a fitting in the driveshaft tunnel.
                      See my website for info and pics.
