Well I went to go on lunch break. I get in the car as usual and start it then roll down both windows. This time only the passenger side moved. I popped the button casing off and it was plugged in fine. I'm guessing since the passenger side worked and the drivers didnt function whatso ever, that I'm not dealing with a fuse problem but a window motor problem?
Am I correct? If so does anyone know how much it will cost to replace and if I could do it myself? Thanks for the info guys.
<a href=\"http://www.cardomain.com/id/HiWire\" target=\"_blank\">http://www.cardomain.com/id/HiWire</a> <br />1997 Dark Green Firebird <br />1997 White T/A
either the motor died or the switch died, pick your poison (i had to replace the driver side window switches a couple months ago, was like a 10 dollar replacement).
ya but if the other one works it most likely the motor....oh BTW if you want a MUCH better faster motor goto autozone and buy the 50$ motor I was talking about, just tell em the car and the year...lifetime warranty as well ;)
Most likely that is what I'm gonna do [img]smile.gif[/img]
Well maybe it isnt the motor...I just started my car and the windows went down fine, however when I tried to bring the driverside back up it stayed down. I turned off the car, took the key out then opened and closed the door. Started it, and then it went up but wouldn't go back down. Im totally lost on what this could be. Electrical? Maybe it is the fuse? Which fuse is the one for the power windows?
