Changing Spark Plugs - FirebirdV6.com/CamaroV6.com Message Board
  • Changing Spark Plugs
    Hey guys...I was trying to change the plugs on my '98 3.8 today, and encountered a bit of trouble. The two in the front were easy, and I also managed to get the rear one on the driver's side. The two rear on the passenger side and the middle one on the driver's side were much harder though, and I ran out of daylight before I could get anywhere with them. It seems that it will be easier to do these from underneath the car, and that is how I tried to do it. I was wondering if anyone out there knows an easy way to take care of this? Any tips would be great! Thanks
    ArcticWhite 98 3.8L t-tops! 5 spd.<br />Billet Grille<br />17\" y2k vette rims<br />Kuhmo 755\'s<br />Dual Flowmaster<br />Killer Sound System
    Did you remove the heat shields on the exhaust manifolds?
      No, I didn't think about that. Will do. Thanks
        All I know is that they are a piece of cake with headers!! :D
        <b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
          An easy way to change the plugs...lol.
          They will never be easy with stock manifolds. What will happen is that they will seem easier to you over time. With practice, you won't think it is such a big deal. It takes me about 5 minutes each to change #4 and #6 cylinders. (Became a nightly ritual for me changing those two plugs)
          Make sure you have a variety of extensions, wobbles, and more importantly ..... patience. Get use to the idea of being able to work without even being able to see exactly what your hands are doing. Oh yeah, make sure you have alot of cuss words ready and bandaids.
            just use a spark plug puller....
            what it is is a socket.. with a 3/4 inch "bolt" on the end but also has the regular spot to put the wratchet... using that meathod guys its EXTREAMLY EASY! YES EXTREAMLY
            btw i got the passenger side middle one from the top...using extentions and swivels... thats the only ***** plug for me
            91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
              i did mine from the bottom...seemed easier for me
                I did all 6 from up top using:
                spark plug socket
                2" extension
                ratchet
                mechanix gloves (yes, I consider them indisposable after this job, saved my hands many, many times)
                Took me about 2 hours, I even managed to fit in the torque wrench to torque them correctly [img]smile.gif[/img]
                But I also have tubular manifolds.
                Really the hardest part is getting off the boot. Mechanix gloves help a lot here because you don't have to worry about the hands so much & it helps with the grip. My boots were quite stuck on there.
                The spark plugs on my mom's blazer are a beast though. Took me two hours to get two changed. Heavy use of a swivel here.
                2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
