My car has some interesting issues. First off the car will die at a stop sometimes. There is no, stutter or anything, just dead. Then the speedometer only works once in a while. Also the brake light that would normally come on if ebrake was set stays on. Maybe these are all related. I was thinking maybe the idler has issues. What do you guys think. I might have posted something about this before but it went away for a while and came back recently after I had to slam brakes to miss a car on freeway.
Issues
Re: Issues
Just for other possible issues.. Your alternator could be going or you have some corroded cables or connections. Check the ground straps to the engine, (on the drivers side and near the AC), and of course the battery terminals.
As for the brake like, I can't remember exactly if it was the ABS light or ebrake light that stays on if the third brake light bulbs are blown. Something easy to check. If it's not that, then I would look into pulling the console open and looking at the electrical components of the brake lever. I don't know exactly what you'd be looking for down there since I haven't had to do it myself but I imagine your problem could possibly be down there with the brake light.
TEAM C6V6
Re: Issues
The wire that goes to the e-brake is easy to find, so like blizz said, take a look at that, in my car it's just a single wire at the base of the e-brake mount...Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
Re: Issues
I don't think it is the alternator. Car has no issues that point towards no charge. Observed it today and when this happens the rpm's drop all the way to 0 and it dies. But this doesn't always happen.... on the brake indicator I will check the rear brake lights and see. Speedo I am still confused about.
Re: Issues
What about a dying pcm? When mine fried, it had sortof the same issues. And when I replaced it with one out of the junkyard, it ran fine, cept for the speedo because mines a stick and the junkyard computer was outof a automatic car.
Re: Issues
When my ignition switch died a couple of weeks ago, it created a lot of weird issues. spedo, tack and volt gauge would bounce around, had to hold the key to keep it running, security light doesn't come on as much as it did before.
