I'd say around 40-55 mph, if I keep it at a constant speed it feels like it's stuttering a bit. I've changed plugs and fuel filter recently. Any suggestions? Could it be the wires or anything of that nature?
3.4 stutter
Re: 3.4 stutter
If its not that. Then its your transmission. It deals with a transmission and the sunshell in connection with some kind of band (what a guy told me), and causes the rpms to be lower than what they need to be. And In turn you may get like a (studder or like a chug) happens to my old car alot.
edit(happens usually between 45 and 60)
Re: 3.4 stutter
ok, so here's an update... cleaned the IAC real good. Then I replaced the TPS... still happens... I'm wondering if there's anything electrical causing the problem. I pulled into advance auto today to get some plugs and wires and as I pulled in, my horn started going off without me touching it, I had to pull the fuse. I put it back in and everything was fine, then on the way home the car was driving great...I'm stumped. I thought it could have been an injector at first and I put some seafoam in the gas tank as well. It's confusing the crap out of me.
Re: 3.4 stutter
Originally posted by Derek3.4 View Postok, so here's an update... cleaned the IAC real good. Then I replaced the TPS... still happens... I'm wondering if there's anything electrical causing the problem. I pulled into advance auto today to get some plugs and wires and as I pulled in, my horn started going off without me touching it, I had to pull the fuse. I put it back in and everything was fine, then on the way home the car was driving great...I'm stumped. I thought it could have been an injector at first and I put some seafoam in the gas tank as well. It's confusing the crap out of me.
you can unhook your battery, wait 15min, then pull the airbag to see if everything is ok, it should come out with 4 torx screws. You can make sure everything looks ok there.
as for your other problem, it could very possibly be a trans problem, i would suggest draining the fluid and replacing it and a new filter, DONT get it flushed though.
it may take care of the problem
