Recently my horn stopped working when I had a guy put an ignition lock cylinder in my car. So I took off the horn and looked to see what was up, there seem to be these two clear brackets on either side of the horn with a positive and negative.
The clear bracket on the left had a loose posi I guess he broke off both of the brackets when he changed it. I noticed when I took the other bracket off a small spring fell out.
Needless to say the other side didn't have one so im assuming that he dropped the other one when he changed the cylinder and broke the two brackets off. Okay here is the issue and my questions.... When I get ready to hook the wires back up what can I use to make the posi wires stay since the holdings for them that were inside the brackets broke off.
2 Do the springs have to be there for the posi connections to work and if one side doesn't have the spring would that make the whole horn not work? If so where can I find the springs to buy because as you can see its kinda small.
