Ihave a 99 camaro with about 35000 miles on it and the check engine light comes on, stays on for a few days and the goes out and then comes on again. no change in the way the car runs. Iused a code scanner and it showed two codes. p0171 system too lean bank 1 and p0174 system too lean bank 2.do you think it's the 02 sensors or are the 02 sensors reading a problem with something else? thanks
