Standing water inside my car . . . suggestions? - FirebirdV6.com/CamaroV6.com Message Board
  • Standing water inside my car . . . suggestions?
    Noticed a bit ago that the driver-side floor of my car was a bit damp . .. okay, it was soaked.
    Today I found nearlly an inch of standing water sitting in that spot right behind the driver's seat.
    The rest of the car is dry for the most part. The water does move to the front of the driver's side while driving, but where's it coming from?
    Anyone else had this? Where's the problem and what can I do about it?
    Hey, this problem comes up every once in a while. Don't remember what exactly, but I fuzzily recall it coming in from the back seat area. Sorry, I got bad memory nowadays. Did you do a search?
    [img]graemlins/burnout.gif[/img]
    Edit:
    http://www.camarov6.com/cgi-bin/ulti...c&f=1&t=006476
    http://www.camarov6.com/cgi-bin/ulti...c&f=1&t=006141
    [ March 30, 2003: Message edited by: F1GT ]</p>
    1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
      I should know better ;) - -thanks!
        One idea to trace the leak that may be easier than stripping the car - try turning the leak inside out.
        Start the car. Run the vent/AC/whatever on full blast. Douse your car with soapy water (it needs a wash, right)?
        You might get lucky and find your leak blowing bubbles at you :)
        Won't work as good for underside or engine bay leaks, but top and sides should be good.
        -Jeff
        2001 Pewter Firebird Y87, M5
        Go Sabres!
          check that little cheap looking piece of plastic between the window and the A(B?) pillar...
          mine was a little undone, and it caused some bad leaking.
          2011 Camaro LS 6M, in black.
            I've got this trouble on my car
            I was AC evacuation which was blocked...
            piece of **** in the evacuation tube....
            FRA, Whisper Lid, K&N Filter,MAF Screen removed...<br />My camaro can speak french!
            • 187shark
              by 187shark
