power windows rolling up slowly - FirebirdV6.com/CamaroV6.com Message Board
  • power windows rolling up slowly
    I just replace my pw motors a few monthes ago and it seems week by week they keep going up slower and slower. So I was thinking that maybe I shoulds greese up the tracks and regulator. but what do I use and where should I put it. Or is there anything else helping the window go up that I can replace to make it go up faster.
    Gary
    [ July 30, 2004, 01:18 AM: Message edited by: crasher ]
    I just grease everything that moves, usually just use a good heavy bearing grease, works for me.
    I will say however if both are going up slow you might have power issues with a bad ground or something like that, just a possibility
    -Brad
    2000 V-Star Custom 1100
    :rock:
      I used a high-temp caliper grease (just because I had alot of it) on the window tracks, and it worked great! Once you get the doorpanel off, you'll see the metal tracks the window slides on. Grease them tracks on the inside of the "C" groove. Hard to explain, but you'll see what I mean when you get there.
        thats guys guess I'll try that the next day I have off
