ALL THE SENSORS on a 97 engine is the SAME as 98 engine. the wiring harness from the 98 should plug right into all the sensors from the 97.
(id use the sensors that youve replaced recently. "no sense in using old sensors that youve already replaced once")
NO. The 97 and 98 wiring harness are a different p/n. One or more of the sensors are different.
It can be tedious work going through and finding the right picture, then the right part, and then comparing p/n's but it's the best way to ensure that the parts are or are not interchangeable between years...
Custom interior...
nope sensors are the same, pinouts are different at the PCM maybe, but the sensors themselves are the same. No need to swap sensors out unless the 97 has some bad ones. Just use the 98 harness and it will be a direct swap
