Cheap fix needed for heater hose quick connector...... - FirebirdV6.com/CamaroV6.com Message Board
  • Cheap fix needed for heater hose quick connector......
    One of the ears on the quick connect broke off and the hose popped out of the hole and sprayed out antifreeze everywhere.
    From what i read the full hose and connector is one piece and costs an arm and a leg. I refuse to pay that when GM should of just used a nipple and hose clamp. Especially when i really only need a new o ring and quick connect small clip.
    Ive read others useing new gm metal quick connects but they are $50 bucks a piece,,,im I the only one who thinks thats robbery still??
    Has anyone else had this issue and fixed it without these dumb priced parts. (this is on the wifes 97 3800 firebird)
    Re: Cheap fix needed for heater hose quick connector......
    owning our cars is sort of like living in the ghetto, u get robbed regularly ;P but yea the prices of some of these things are kind of retarded. good luck :)
      Yeah, the clip is stupid, but that's not why I replaced mine. The freaking hose melted. Buying a new one was expensive, as you've realized. I went to a junkyard for this item. He wanted about $50, but another guy tried to stiff me for $150.
      I shoulda kept the clips off the old one and sent 'em to ya. :(
        maybe ask some of the guys that have cars listed on here that they are parting out if they still have that part?
          i feel ur pain, they just got me for the two heater hose gaskets at 15 a piece
            you could tap the port with threads and screw in a fitting from the hardware that goes to barb, then clamp the hose to the barb end. Just make sure to take the tensioner bracket off first so you are not putting metal shavings into your cooling system
            http://www.bowtiev6.com/
              i think ill skip taking the tentioner off,,, its brand new,, last guy just put a new one on,,, maybe he cracked the clip and thats why it broke. If i mess up the threads ill have to spend more money,,, and its not my car or money so i dont wanna take that risk.
              as for getting a clip on here i thought of that,,, im in canada and kinda need something now. the car is stuck in the yard and untill i can fix this i cant even start it. but is an option.. thanks
              any one have any other ideas?? are universal quick connects sold anywere (male part) that i can just clamp to the hose.
                Find a brass hose barb connection and epoxy it on the aluminum housing.
                OR,
                Find a nylon hose barb and see if you can get a tight friction fit.
                  Doesn't the 3.8 in FWD cars use a different system than ours, with normal hoses? If so, is there a way to put those connectors on our engines? Or is this all part of the tensioner assembly?
                    yah its part of the tensioner in our cars not sure what others use.
                      OK, so then will a tensioner off a 3.8 FWD work on our cars? If it does, that will be a good thing to remember someday when I need to replace the tensioner.
                        Go to this website. http://www.v6fixit.com/
                        They make aftermarket hose connectors and they sell a hose kit to make the hole repair. Plus its a hole lot cheaper then the dealership. Worked great for me.
                          My Hptuners stop working
                          Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
                          14 hours ago
                        • Money pit
                          Zzp cams
                          by Money pit
                          Has anyone used zzp gt1 cam if so is it worth the money and time
                          2 days ago
                        • thatpewterfirebird
                          2001 3800 s2 firebird
                          by thatpewterfirebird
                          4 days ago
                        • Turbo 3800 camaro
                          Where are the videos?
                          by Turbo 3800 camaro
                          Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
                          6 days ago
                          New Chevele
                          Just saw it on Facebook, looks awesome. The front and rear nice looking....
