octane v.s. plugs - FirebirdV6.com/CamaroV6.com Message Board
octane v.s. plugs
  • octane v.s. plugs
    i was wondering...........
    since our cars need only 87 octane.......
    in my country they only serve 93 or 95 octane
    our cars are 9:0.1 compression, so i guess a bit goes unburned,and since i never overhauld my engine, i guess the compression ratio should be a little lower. and since i removed my cat and put a flowmaster, i guess the the flow leaves my cumbostion chamber too early leaving a part of the fuel unburned (I SEE A SLIGHT BLACK SMOKE) ( correct me if im wrong)
    SO MY QUESTION IS :::: CAN I USE A HOTTER PLUG FOR OUR HIGH OCTANE FUEL?? MAYBE IT CAN BURN IT MORE EFFECTIVLY,, BUT I HAVE MSD COILS AND WIRES AND I CHECKED 3 OF THE PLUGS TODAY AND THEY WERE NICE BROWN COLOR,, NO SINGS OF RICHNISS
    HELP
    Octane levels do not alter your a/f mixture, as far as less compression due to a older motor not always so most of the time as long as rings are good u will have more compression due to carbon build up on top of piston. Yes u can go 1 stage hotter to burn more effectivly. another possibility is a leaking injector a faulty fuel pressure regulator. plugs dont always show richness.
    2004 srt4 few goodies<br />13.3 @ 103.4
      umm
      you could get a DIS 4, my 3800 with no turbo would barly run because it was so rich, after the DIS-4 it runs ALOT stronger and it doesn't get misfires from no ware any more
      www.turbov6camaro.com
      1997 3800 Series II Camaro
        well, there's a LOT of misinformation in this thread...
        our compression ratio is 9.4:1.
        Yes our cars say 87 octane, but an LS1 can also take 87 octane. Using the autotap program, at WOT i would get almost 7* KR using 87, about 3* using 89, and next to nothing using 93.
        Is KR a bad thing? Not for daily driving purposes. KR merely retards timing to prevent detonation, or knock. Are you getting the full potential? no. Is it safe, yes.
        [bandwagon] just run some seafoam thru it [/] lol
        2011 Camaro LS 6M, in black.
