when my engine is cold.. like mornings after sitting all night. i turn my car on. and hit the gas, and it feels like im misfireing so bad. like its only running 3 cylanders. but after about 15 min of driving.. all that missfireing feeling goes away..
could it be my dirty air filter? lol
or fuelfilter? or fuel pump?
i want to fix this..
96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
like you will tap on the gas and it feels as though it could shut down? Its just because it is cold, mine does the same thing after it has been sitting for a long while. After warming up it goes away and i can rev normal. Nothing is wrong
96 3.8l green camaro Y87 <br />(Sold January 28th, 2004) New whip (02 Civic SI)<br />\"Out with the bad..in with the good; out with the bad in with the good!\"<br /> <a href=\"http://members.cardomain.com/themeangreen6\" target=\"_blank\">http://members.cardomain.com/themeangreen6</a>
it seriously shakes like its running only 3-4 cylinders.. its bad!
lol.. but im always in a rush to make it to school on time every morning! [img]graemlins/crybaby.gif[/img]
If it has been a long time since the air and fuel filters have been replaced, then change them. If you still have the misfires, give it a good tune-up. It shouldn't be misfiring like that when it's first started. You need to get it fixed before the problem get worse.
so...something COULD be wrong with the internals of my car?
<blockquote>quote:</font><hr>Originally posted by Tyler: so...something COULD be wrong with the internals of my car?<hr></blockquote>
dude it's just general aging of the car most likely. I have a similar problem with mine but it's with the transmission. If I take it out to drive for the first two minutes w/o letting it sit and warm up it'll be reluctant to shift and when it does, it shifts HARD...HARD enough to knock my foot off the gas...probably could chirp them tires if I actually went WOT... [img]tongue.gif[/img]
Mine was doing that when my O2 sensor was going bad. No codes, just really rough idle and sputtering.
Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
