dying - FirebirdV6.com/CamaroV6.com Message Board
dying
  • dying
    So I am still having this problem. Car dies when coming to a stop, usually on a hill. It doesn't happen every time, occasionally but still annoying. Not sure where to ever start. I doesn't sputter or any thing just sudden idle drop to 0 and dead.
    Re: dying
    I was thinking IAC but it doesn't idle high or anything and it only does this coming to a stop after driving a bit.
      Re: dying
      You might check for a vacuum leak, brakes are vacuum boosted so it causes a change in pressure(or lack thereof as it is) when you use them, could be causing erratic behavior
        Re: dying
        Poor idle and stalling when letting off the gas or coming to a stop is a symptom of an EGR stuck open. Or, if the engine speed slows down in a linear fashion as you slow down until you stop and it stalls, that could be a stuck TCC (if you have an A4). But that would feel like if you were coming to a stop with a manual transmission and you left it in gear. But that would feel like a bump-bump-bump right before it dies.
        Does it sound like either of these?
          Re: dying
          maybe this is not your case,but i want to share it either way......when my 3.slow ummm sorry..3.4 did that ,, i was using the a/c.......the thing is ...it needed some freon in....
            Re: dying
            Tim, that could be because I noticed a long time ago it was a little harder to brake. I happened to be saying this in the barber shop and the autoparts guy was there and suggested the brake booster. Never thought that would affect the engine so I just have dealt with it since then.
              Re: dying
              how old is your alternator/battery?
              i would clean the terminals on the battery and put a tiny bit of grease on them to prevent corrosion.
              The reason i say this is if you have a weak spot or bad battery connection, the car may stall when hitting the brakes, i have a car sitting in the garage and i use a weak battery and a charger to start it.. when i hit the brakes it instantly stalls out, if your battery is a bit weak, it may happen if the alternator cant get a good enough charge on it.. just a thought.
                Re: dying
                Checked all that. I think this vacuum leak is sounding good.
                  Re: dying
                  1 of your injectors could be bad, mine did this also about 7 years back.
                    Re: dying
                    IDK if this is it but mine started doing this like a year ago but it stopped. ended up being the crank shaft sensor.
                      Re: dying
                      check battery and alternator connections too.
                      1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
