radiator question - FirebirdV6.com/CamaroV6.com Message Board
radiator question
  • radiator question
    hey ya'll, i need to ask a question, i did look for a "how to" link of some sort on here so my appoligies if i've over looked it, but any help or a point in the right direction would be greatly appriciated, i have a '98 camaro with the 3.8 & i need to look into changing out my radiator myself, i've read in both the haynes & chiltons manuals (& we all know how realiable those things are-lol!) that you have to UnHook the Air Conditioning Lines on the '98 model & Take It Out From Underneath??? it just seems like there should be a way for it to come out from the topside & without unhooking the a/c lines? btw-she's an automatic if that makes a differance (read; tranny cooler lines) ...just wondering if anyone who's done it before had any input or advice cause from my experance the chiltons/haynes manuals ofter overcomplicate things-hoping this is the case here--thanks
    Re: radiator question
    ...bump
      A Google search revelaed these:
      http://www.ehow.com/how_4487132_repl...vy-camaro.html
      http://wiki.answers.com/Q/How_do_you...or_1996_camaro
      I've removed radiators before on automatic and manual transmissions from quite a few different makes/models over the years, and I've never had to disconnect the A/C lines in any of them.
      When I pulled the radiator from my '96 Camaro 3.8l to have it thoroughly cleaned by a shop (because of the damn dexcool sludge!), it came out with relative ease.
      ...Although, it was an M5, so I didn't have to worry about the trans lines.
        You thinking of the ac condenser that sits in front of the radiator. Once you take off the plastic wind deflector that sits over the radiator you can simply pull up on the condenser to seperate it from the rad. Its only held on by a couple of tabs.
          Just wondering, do you need a radiator?
            the condenser is not attached to the radioter....4 tabs thing holds them together..its not dificult but have a six pack close by.....
              yeah...i think im probally due for a radiator, its full of that, as hockeyman called it, that d**n dexicool sludge! was just wondering if its something i should try to do at home in the driveway or something i should try to do on the lift at my buddys garage-thats why i was wondering if i could take it out from "topside?" or if it had to come out from the bottom of the car? ...sounds like it has to come out from underneath? right? -as always, thanks for the help & the good advice! yall rock! ...i probally wouldve done struck a match & collected the insurance money if it werent for you all! (haha!)
                its on an ls1, but it should be the same exact thing..
                http://www.ls1tech.com/forums/12171575-post2.html
                  cool...thanks a bunch!
                    Very easy to do,get new hoses clamps and premixed coolant or make sure you use distilled water.
                    I did mine last summer.
                    I got a Spectra Premium #CU1485 the core was about twice as thick as the factory POS.
                    Took me a couple of hours.
