General Questions - FirebirdV6.com/CamaroV6.com Message Board
General Questions
  • General Questions
    I wanted to get some weather stripping since I did a conversion on my car from hard to T. I was curious tho what kind of adhesive do I need to make it stripping sit in place? Another question is Will the headliner from a T-Top bird go in a Camaro? Also Will the mirrors from a Firdbird bolt up to a Camaro I was gonna go for somthin diffrent since I needed to get some new side mirrors anyway. And I think I might need to change the gaskets on my Intake Manifold because my car is leaking water and since I can't tell where its coming from I was assuming it was the intake manifold gaskets. No leaks from the firewall, heater core, hoses, or anythingelse. Is that hard to change?
    Re: General Questions
    I have the complete weatherstripping setup, it doesn't appear to use any adhesive, just tension.
    Would work just fine, I believe they are EXACTLY the same.
    Should bolt right up. Might look a little funny....
    Plan on about 3 hours and 6 beers. It's not that bad to pull the intakes. Main PITA is the cross bolts in the lower, and the 90 degree plastic bend from the water pump to the lower.
