coolant leak, whats this hose called? - FirebirdV6.com/CamaroV6.com Message Board
  • coolant leak, whats this hose called?
    i believe it runs into the tensioner and is right by the alternator
    Re: coolant leak, whats this hose called?
    heater hoses. Dealer hoses, nothing available from gates or goodyear on those unless the clips are ok, then you might be able to find something
    http://www.bowtiev6.com/
      If it is just leaking by the white connectors just pop them off and and let it dry real good and use some GM black sealant around it and let it dry over night. Then you should be fine. I did that on mine or you could try the FWD connectors then you can use the gates rubber hose and some barbed connectorsand hose clamps. I have the whole setup for mine incase mine go out. I have the part #'s on my cardomain with pics of the connectors which are metal and should last along time. If its the hose just cut it where its leaking and use a barb fitting with hose clamps to put it back together. Damm thats a clean engine bay! I'll be here this weekend if you need help with it. I had to do mine with the sealant at the time since I didn't recieve the metal connetors in time.
        Nice engine bay!:eek:
          Exactly what I was thinking! :tup:
          1997 Camaro RS A4
          2006 Chevy Colorado
          2003 Kawasaki Ninja ZX6-R
            Go to http://www.v6fixit.com/ They sell both connectors and the hoses in a kit. Its a better design and cheaper then GM parts direct.
              i love it when you pop your hood... wink wink!!!!
              Team NoVa
