Wiper blade issues - FirebirdV6.com/CamaroV6.com Message Board
Wiper blade issues
  • Wiper blade issues
    Hey i really didn't know were to put this one. But ive been having a problem with my windshield wiper blades. Every time it hits the highest point on the window it goes off the edge of the window by the drivers side mirror. I just got them replaced cause they were old and made sure that they were the right length and they are. So what could be the problem?
    Thanks
    Re: Wiper blade issues
    Mine does the same exact thing but only on high settings. I have no idea what causes it, but I thought mine was because a broken hinge point on the drivers motor to arm piece. Had to fab up a replacement and thought it was slightly off.
      So did you end up fixing yours with that piece you fabricated?
        Nope, but you can try removing the plastic cowl piece right in front of the windshield and see if you have a loose motor arm. Mine is still loose but it works as much as I need it to for now.
        Usually a hinge point bolt breaks because of corrosion, just drill and thread it for a new bolt.
          your motor is loose mine still is to i just never got to doing it yet
            K ill check it after shcool and let you no if that works
