Headlight gear question... - FirebirdV6.com/CamaroV6.com Message Board
  • Headlight gear question...
    Which ones are stronger? Brass or Alluminum?
    I had been having some issues with my passenger side headlight motor for quite some time and it got to the point where it wouldn't raise period. While I was flipping the switch off and on trying to get it to come up, my DRIVERSIDE headlight gear strips and now makes the grinding sound... So my passenger side headlight wont rise, and my driver side headlight gear is stripped.. ..I'm going to replace both with entirely new motors and the new motors have a screw design making the gear swap much simpler (which is the reason the passenger side has issues I believe)
    Which gears should I put in my new motors?
    1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
    Re: Headlight gear question...
    I had been having some issues with my passenger side headlight motor for quite some time .........
    The brass are reported to be better, but I believe they are no longer available (new anyway). The last I read was the outfit that was making the brass gear is now only offering an aluminum gear. Either are stronger than the OE plastic.
    • 187shark
      by 187shark
