hey guys, im just wondering what engine beside a 3.8 i can put into my 2000 bird that can give me more power, without changing wiring and gas lines, etc. thanks guys
engine swap
Re: engine swap
Any motor you go with will require work including wiring harnesses, suspension, transmission , rear end, radiator, possibly a steering rack, firewall/wheel well modification depending on what it is. There really aren't any easy swap in solutions even an LSx swap will nickel and dime you to death.
Re: engine swap
any engine you put in is going to require rewiring and such. Nothing is plug and play drop right in other than another 3.8 engine with the same intake design
Re: engine swap
Originally posted by DaBird19 View Posthey guys, im just wondering what engine beside a 3.8 i can put into my 2000 bird that can give me more power, without changing wiring and gas lines, etc. thanks guys<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: engine swap
Originally posted by Bird_Of_Prey View PostDon't be listening to the haterz. I just finished an LS1 swap into a 99 Camaro last week. Granted, I had a complete donor car. That would be the only way I would ever do it. You use all the LS1 engine wiring, V6 interior wiring and V6 underhood fuse boxes. I really think we could do it in a day if we did it again. I'm even using the V6 fuel lines and tank with a V8 pump.
Re: engine swap
What major modifications would be involved in swapping in a 3.8 Turbo from a Buick GN?
I have a magazine somewhere on the bookshelf that has a great article from a few years back. The guy took a black 4th gen '93 Firebird Formula, yanked out the LT1 and replaced it with a 3.8 Turbo from a GN. I need to find that magazine article..
Re: engine swap
Originally posted by bigairboarder44 View PostHow'd you use the V6 fuel lines?<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: engine swap
Originally posted by Jtels2593 View PostWhat major modifications would be involved in swapping in a 3.8 Turbo from a Buick GN?
I have a magazine somewhere on the bookshelf that has a great article from a few years back. The guy took a black 4th gen '93 Firebird Formula, yanked out the LT1 and replaced it with a 3.8 Turbo from a GN. I need to find that magazine article..<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: engine swap
Originally posted by Bird_Of_Prey View PostIt has the same fittings as the LS1 rail. Plugged right on. Just didn't use the return, since the LS1 is returnless.sigpic
Re: engine swap
i would do that if i get a v8 doner car(for free).............otherwise,,buy one as i did......believe me with a v8 you will be very happy.....just try driving one.....and you will see why i gave the v6 for free to my sister.Last edited by 3.4orNothing; 05-14-2010, 09:48 AM.
Re: engine swap
Originally posted by Bird_Of_Prey View PostNot as cut and dry as one would think. You would have to find a GN engine (expensive), then find 3.8 Series 1 Front wheel drive heads, to fit between the F-body shock towers (thats the only way the turbo 3.8 fit in the 89 Trans Am). It's all in that article. Need motor mounts too.
YEap that's what you'll need but id rather do that than another LS1 swap. No offense to anyone here who's done it.
With the L98 you would have to do the same exact mods, I think you'll have issues with the trans though.
