de-carbonizing engines - FirebirdV6.com/CamaroV6.com Message Board
  • de-carbonizing engines
    what is the best way of cleaning the carbon from our engines, i've heard sea-foam is good, has anyone used it, is it easy, and does it work well and with what performance/other affects
    97 camaro<br />black, 5 speed, t-tops, rockford fosgate cd w/4X6.5\" rockford speakers, 3\" flowmaster american thunder catback with 3\" carsound cat, SLP CAI, B&M Ripper w/leather Hurst shift knob, 5% tint.<br /> <a href=\"http://camaroz28.cardomain.com/id/ianwells100\" target=\"_blank\">http://camaroz28.cardomain.com/id/ianwells100</a>
    My engine acts like new after a half bottle in the TB and the other half in the tank. I highly recommend it for only $6.
      used seafoam in the truck. its not hard. follow the directions on the can. the only problem i can see if that it might be hard to poor it into the horizontal intakes. i believe the can recomends pouring into a vacuum line in this situation.
      i had some carbon buildup and was getting knocking/pinging (higher compression, hot spots). it cured that problem.
        spray you a little nitrous in there. Cleans it out good with a nice side effect. :D
          I intend to Seafoam my car before my next oil change. But since I just changed my oil 300 miles ago, I'll be waiting a while [img]smile.gif[/img]
          In the meantime, I used the Chevrom Fuel injector cleaner w/ the Techron.
          --<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
            The best and easiest way to clean out carbon deposits in the engine it to give the throttle a good whack!!!
            If you run your car on a consistant basis from idle to redline. Carbon buildup isn't something you should really concern yourself with. If you granny the car under 2,000 RPM all the time, then worry about carbon build up.
            <b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
