Brake lights - Spoiler works, neither side works...suggestions? - FirebirdV6.com/CamaroV6.com Message Board
  • Brake lights - Spoiler works, neither side works...suggestions?
    Hey folks,
    Suddenly, my brake lights stop working (except for the cyclops spoiler brake light, it is fine). Tail lights work fine.
    I've checked / changed out the 20 amp fuse.
    Replaced all 4 bulbs in back.
    Checked the ground that is right there next to the trunk release (cleaned, reseated).
    Check conntinuity from the quick disconnnect at the top of the drivers side portion of the trunk to the light bulb holders themselves. All good.
    I'm guessing the problem may lay at the switch itself under the dash, on the brake arm. Are there different switchs for the cyclops and the side brake lights?
    Thx for any help.
    Tim
    Re: Brake lights - Spoiler works, neither side works...suggestions?
    Maybe a relay somewhere. How suddenly did it stop working? Were you doing something at the time , working on the car recently?
      ssms...thanks for the response.
      I have them working now, but not 100% sure of how I fixed it.
      While poking, prodding around under the dash trying to determine continuity from front to back, I had pulled apart what i thought was the turn / hazard swith assy wiring connector (per Chilton's wiring diagram). Looking further along the steering column, tightly attached to it, was another wiring connector block. One end of this appeard to have worked itself loose on one end. I popped it back down and the brake lights started working.
      I began to button things up, and they quit again...damn. Re-seated it, tried to make sure there is no strain on any wires, and they are working now.
      I'll keep an eye them, but for now, fingers crossed, it's fixed.
        Good to hear.
          The brake lights feed through the turn signal switch in the column IIRC. But the CHMSL doesn't.
