Clunking need help - FirebirdV6.com/CamaroV6.com Message Board
Clunking need help
  • Clunking need help
    Alright when I first start my car and turn the wheel to the right it makes a slight clunking noise but it never makes that sound again. Any help or suggestions are appreciated
    Re: Clunking need help
    maybe the ABS...not sure....post a video...better for these cases
      Maybe something is rubbing underneath the right side.
      Leonard
      www.fquick.com/96V6Junkie
        power steering - had a buddies car do that when he was low on fluid
          Ftw. :tup:
          Leonard
            I'm tempted to say it might be the steering column shaft and the bolts aren't tight enough? When i replaced my k-member and steering rack i didn't tighten those bolts enough and it did that when in a a full lock to lock turn standing still and at one point it slipped and threw the alignment way out. but if you haven't had anything serviced or the shaft out i find it far-fetched that this would be the problem. hope this helps
