Car wont start - FirebirdV6.com/CamaroV6.com Message Board
Car wont start
  • Car wont start
    Ok, so my car died last night in Mcdonalds drive through, which is weird. After some cranking it started back up, it acted like it had ran out of gas, but i have half a tank. After i started it up it ran fine th rest of the night. Went home got up this morning, and it won't start. It turns over and everything, but wont start. I'm pretty sure it isnt getting gas. Theres no gas smell, and I pressed those relief valves on the fuel lines and nothing came out. Checked the fuses and relays and they all seem to be fine. I also can't hear the fuel pump turn on either, I usually can. Do you think the fuel pump is the culprit here?
    Thanks
    auto, aluminum driveshaft, Fast Toys Ram Air, !air silencer, smoothed lid, Pacesetter shorties, 2 1/2" exhaust, !cat
    New Time:
    15.11@91.14
    Team 3M Mafia
    New Times coming soon
    Re: Car wont start
    Check for fuel pressure at the injectors
      Re: Car wont start
      I pressed one of the valves on the fuel rails and nothing came out
      New Time:
      15.11@91.14
      Team 3M Mafia
        Re: Car wont start
        Doh, if you can't hear the fuel pump prime it's probably the fuel pump.
          Re: Car wont start
          Well i put a whole new sending unit in it, at least i though it was new, with a new fuel pump probably 10,000 miles ago, but I got it off of Ebay. I have another fuel pump and sending unit so if thats what it is I will just switch the fuel pumps and see if that works.
          New Time:
          15.11@91.14
          Team 3M Mafia
            Re: Car wont start
            Sounds like fuel pump, you checked all the wiring at the fuel pump too? Im sure you've done this, but maybe change fuel filter. Goodluck let us know how it goes
              Re: Car wont start
              yea i just chaged the fuel filter a month or two ago. I'll check the pump out and see when I have time to.
              New Time:
              15.11@91.14
              Team 3M Mafia
                Re: Car wont start
                ok so i put in my old fuel pump that worked fine when i took it out for a new sending unit. Still not getting fuel. Does anybody have any idea??? checked all fuel pump fuses and relays...they seem fine..really need some help on this one!!!
                New Time:
                15.11@91.14
                Team 3M Mafia
                  Re: Car wont start
                  i would try changing the fuel filter again, its very possible you got bad/dirty gas and it clogged it.
                    Re: Car wont start
                    no i un-did the fuel pump's fuel line at the sending unit and no gas came out so i know the pump's not working. weird thing is it started later that day after it wouldn't earlier in the morning. I drove it to my dads so i could work on it, and it died once, but started back up. now it wont start again, even after changing the pump
                    New Time:
                    15.11@91.14
                    Team 3M Mafia
                      Re: Car wont start
                      Make sure your tubes are clamped down very well on the pump. I had a mysterious problem once.. Bought 2 walbro's cause I thought I had a defective one. Just turned out to be the tube.
                      TEAM C6V6
                        Re: Car wont start
                        wouldnt think it would be the tubes since its the factory sending unit and it doesnt prime anyways
                        New Time:
                        15.11@91.14
                        Team 3M Mafia
                          Re: Car wont start
                          no other opinions?? i REALLY dont want to take this to a shop!
                          New Time:
                          15.11@91.14
                          Team 3M Mafia
                            Re: Car wont start
                            Ah yeah my bad. I see now. Have you tried changing out the fuses and relays anyways? Like.. borrow one from something that matches? Unless that's how you checked them already.
                            TEAM C6V6
                              Re: Car wont start
                              yea switched relays around and everything
                              New Time:
                              15.11@91.14
                              Team 3M Mafia
