Oil Leaks - FirebirdV6.com/CamaroV6.com Message Board
Oil Leaks
  • Oil Leaks
    ok. So the past couple of week I have been doing lots of work on my 1996 Camaro. I put headers, new oil pan, new oil pan gasket, new oil pickup screen and changed the rear main seal(cover and seal part), changed transmission filter and fluid and cleaned all parts up. It leaked oil before and this is the reason I did all this work. This ***** leaks more now than ever before. I mean it leaks 12in in diameter within a few minutes. It doesn't leak if its at a incline alot but as soon as it on its own it starts pouring out the hole the bell housing part. What the heck is wrong. Is this the oil pan or rear main seal leaking?
    Re: Oil Leaks
    the rear main seal will only leak when the engine is running, it is the oil pan.
    how much did you torque the oil pan gasket bolts down?
    they should be very loose, just a tiny bit tighter than hand tight, its possible that you crushed the rubber seal on the gasket. They also recommend putting a tiny bit of RTV on each of the 4 corners of the oil pan and the engine block
      Re: Oil Leaks
      I just took the starter and bell housing plate off and its leaking I believe from the 2 rear corners. Could I take the oil pan back off and then rtv those 2 corners and put it back in or is the gasket now toast?
        Re: Oil Leaks
        the gasket should be fine, just loosen all of the bolts, the pan will drop low enough to stick your finger in there and put the rtv on
          Re: Oil Leaks
          Ok. Is there any possibility that the cover for the rear main seal could be leaking at the bottom cause i changed that gasket also but it looks to be dry up to, or is this a common issue with these oil pan gaskets? Also does it matter what kind of rtv I use? I have copper and I also have the grey kind I think.
            Re: Oil Leaks
            i wouldnt use copper stuff, and im not sure what the gray stuff is. I used permatex blue.
            anyways, its doubtful that it is leaking from the back plate.. its been a few years since i replaced that gasket, so i dont remember all what was back there, but i think that plate just covers up the cooling ports.
            since you said it didnt leak when the car was on a hill (assuming the front of the car was down) it has to be the oil pan, there isnt enough oil in the engine for it to leak from the rear main, not to mention the baffling on the gasket to keep oil in the pan
              Re: Oil Leaks
              It's actually the total opposite on the hill thing. It doesn't leak as bad when the front of the car is up but when it's level it leaks more but then again that was when the bell housing cover was on so maybe when it's level it let's the oil come out easier. I do think it's the oil pan gasket though.
                Re: Oil Leaks
                Well I dunno what is going on. Took the pan back off and rtv'd the corners like you reccomended and it is worse now than before. I am also thinking the rear main cover is screwed up as well. I am just going to pull the transmission back out and redo everything and replace that expensive oil pan gasket again. This totally sucks. Add's another week or two since I have no time to work on it and means I am going to be spending $50 for 2 days worth of driving to class and back.
                Enough of the rant just giving a update.
                  Re: Oil Leaks
                  well, that is good news (possibly)
                  the oil leak is most likely the oil pan gasket.
                  when you are tightening the bolts are you making sure you tighten them in different spots on the pan, and not just doing the ones that are next to each other? its really easy to warp the oil pan that way.. or your oil pan could be warped and thats why you have the leak (im assuming you replaced the oil pan gasket because of a leak in the first place)
                    Re: Oil Leaks
                    Well I hit something and the oil pan needed to be replaced so I got a new gasket for it. Yes I am tightening the pan in different places. I just don't know what is going on.
                      Re: Oil Leaks
                      I agree with cam98aro with the oil pan possibly being warped... is this one from a junkyard or is it brand new?
                      Custom interior...
                      TEAM NoVa
                        Re: Oil Leaks
                        It's brand new.
