Has anyone noticed issues with starting the car when its hot out, or after its been driven for +30 minutes on the highway? It takes a little longer to crank, and the subsequent vroom that follow is muted. It has a newer Interstate battery installed last year, and this problem doesn't happen on cooler days.
If you suspect the battery being the problem get it load tested. During startup there are a few variables that change the target rpm range, like coolant temps.
You can increase the ground wire gauge from the block to the body/battery and the alternator to battery wire gauge to help out some.
