I had a problem with the car dying while idling and there was no spark when trying to start the car. Before that, I had put new delco iridium spark plugs and wires. Since there was no spark, I assumed it was the ignition control module. I put a new one in and now it there is spark and it tries to start but it there is some kind of popping like misfiring and it won't start. All the cables are set up right, I checked them 3 times. One coil is also new. What could the problem be?
Can anyone please help me? ICM and crankshaft position sensor problem
Re: Can anyone please help me? ICM and crankshaft position sensor problem
THe problem is that I'm not in the U.S. I'm in Europe and there really aren't mechanics that know this car since its rare..
This is the newest update.. There is no spark going to the middle coil while the other two are getting spark. The car cranks and it won't start. Could it be a wire going to the ICM or something wrong with the PCM ?
Are you absolutely sure there is no spark coming from the middle coil? If that is the case, its possible that either the coil is bad (which is somewhat common) or a bad ICM (which isn't as common).1995 Pontiac Firebird
Well the ICM was just put in. It is new. I rotated the coils and I still get no spark in the middle coil, so the coils are fine, I also had them tested. What else could be the problem? If the ICM is bad from the factory? It was bought at autozone.
Originally posted by Phantom_WS6 View PostWell the ICM was just put in. It is new. I rotated the coils and I still get no spark in the middle coil, so the coils are fine, I also had them tested. What else could be the problem? If the ICM is bad from the factory? It was bought at autozone.Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
Newest thing is now there is no spark on any of the coils. Before that, there was no spark on the middle coil (Cyl 2 and 5) but now there is none on any.
The ICM was a Duralast one from Autozone. It might have been bad. Now I'm thinking of getting a Delco one from O'Reilly's but those are like double the price.
Originally posted by Phantom_WS6 View PostNewest thing is now there is no spark on any of the coils. Before that, there was no spark on the middle coil (Cyl 2 and 5) but now there is none on any.
The ICM was a Duralast one from Autozone. It might have been bad. Now I'm thinking of getting a Delco one from O'Reilly's but those are like double the price.1995 Pontiac Firebird
