well when my car idles the rpms jump a little bit like 100rpms each way and some time it will jump a little more but usually not that much but is real anoying. My volt meter moves back and forth and once in a while will totally go to like 8 volts. And my oil pressure gauge moves aroun when this is happening as well. I also notice at night my lights kinda dim while its idleing wierd. So please any suggestions on what this could be would be great. Thanks
Wierd Idle????
Wierd Idle????
Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
Current Ride
2006 Mitsubishi Evolution GSR
www.myspace.com/shane1015Tags: None
battery and alternator seem fine.....i put them on the volt meterPast Ride
Current Ride
<blockquote>quote:</font><hr>Originally posted by Shane:
battery and alternator seem fine.....i put them on the volt meter<hr></blockquote>
did you have the alt tested under load too? I read that if it is puttinf\g out too much voltage, it could mess w/your gauges1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
