WOULD LIKE TO SEND MY PCM OU TODAY CALLNG ALL 96 Y87 3.8 FROM FACTORY
I am getting my pcm programmed and i need a vin number from one of you guys with a 96 camaro that came with y87 3.42 gears from the factory thanks guys
[ January 29, 2003: Message edited by: SLOWBRAEATER ]</p>
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
tats cool thanks, now if its possible can you get me the service number that is on a white ag on the computer it says serv. number i would greatly appreciate it thanks again
cool, thanks im sorry to bug you bt i need one more favor from you, ok after the number that says service number there are four letters what are the letters on yours is it btac or something else? dave buckshaw will be progamming it for me.
oic so your going to be a negative dick. I see, I was under the impression that we at the board shard information for the betterment of the overall v6 community. **** you then ill find the info from someone else.
