I need to replace a freeze plug on my 3.4 Camaro. It's the 1 behind the block so they say I have to drop the Tranny. Im curious tho is there anyway to just have it lowered and be able to get to the plugs without completely taking it down? Also is there anyway for me to hammer freeze plugs into the back of the block from the bottom of the car or will the screw in rubber ones work okay?
Freeze Plug ?
Re: Freeze Plug ?
The rubber ones are more of a temp. solution. I used brass and alm. ones, just need the right socket to tap them in.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Freeze Plug ?
Originally posted by ThaDyce17 View PostSo the Tranny has to drop but what do u mean by socket? Do U need any special tools for this
to remove the old ones, just get a flat blade screwdriver and smack it with a hammer until it goes into the plug then pry it out
Re: Freeze Plug ?
Originally posted by ThaDyce17 View PostJust a quick question first is it possible for me to do all of this from under the car with the tranny out? and 2 could I just use a regular hammer and be done with it?
the only real way to get them out is to punch them out, the way i found that is easiest is to get a screwdriver and smack it with a hammer so it pierces the freeze plug, then pry the plug out.
the only good way to put them back in is to use a socket (or anything that is a tad bit smaller than the freeze plug) and use that as a drive to get the new plug back in.
you could also use a block of wood, but you need to make sure that the plug goes fully in
Re: Freeze Plug ?
So im thinkin because all the water in my cooling system froze up one day and im thinkin thats what pushed my freeze plug out. But if the plug got pushed out wouldn't that mean that all of them were getting pushed out and that one happened to pop first? So the other ones that im sure were starting to pop out can they be popped back into place or do they need replacing?...... Or is that untrue in itself, and that one just popped and the others are fine?
Re: Freeze Plug ?
If you have the tools do it yourself. But first off realize that your cooling liquid should never freeze for the most part it means that you put a lot of water in your system. And water is bad because it boils at 212.
Re: Freeze Plug ?
Originally posted by ThaDyce17 View PostSo im thinkin because all the water in my cooling system froze up one day and im thinkin thats what pushed my freeze plug out. But if the plug got pushed out wouldn't that mean that all of them were getting pushed out and that one happened to pop first? So the other ones that im sure were starting to pop out can they be popped back into place or do they need replacing?...... Or is that untrue in itself, and that one just popped and the others are fine?
i personally would replace all of them, they only cost like $13 for a set
Originally posted by Slowside View PostIf you have the tools do it yourself. But first off realize that your cooling liquid should never freeze for the most part it means that you put a lot of water in your system. And water is bad because it boils at 212.
the boiling point of water is affected by many things, there is no real set temp it will boil.. i can boil water if it is 33F if i wanted to.
water is actually better than antifreeze to use in a cooling system because it can transfer heat better, but the downfalls of it is it will boil over at a lower temp, it will freeze at a higher temp, and antifreeze provides great corrosion protection.
Re: Freeze Plug ?
I realize this is an old thread, but I remembered this from when it was current, so now that I had to go through this, I thought I would share my freeze plug replacement experience for future reference. This was my winter beater, luckily. The plug started leaking because of age (20 years old) and corrosion. I tried the screwdriver and prying method, and it would not budge. What i ended up doing was taking a torch to it and heating it until it was red hot, then using a ball end of a ball peen hammer to pound it until it popped out. It went into the block, but it was not a big deal. The cylinder wall is right behind there so it didn't go far. I locked a pair of vice grips on it and used them as a lever to force it out of the block. Then I used some fine grit sandpaper and a little brake cleaner to clean up the bore. The new freeze plug went in using the socket and tapping it repeatedly until it was flush with the block. Contrary to some writeups I read on the Net, no sealant was required as it's a very tight fit. Not one drop has leaked since.
Luckily this particular plug was right in the front on a FWD car, so it was easy to access, althought it was still a little tight getting it out. Basically, if you can remove the old plug, there will be enough room to get the new one in. My only concern is that if this one failed, the others are not far behind.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...21 hours ago
